Canadianshee Posted March 2, 2020 Report Posted March 2, 2020 Looking to see if others have other option for clearance or should this be good. Is there a difference between a 4" or 6" length pod filter in regards to effecting performance? Sent from my LG-H873 using Tapatalk Quote
gusto Posted March 3, 2020 Report Posted March 3, 2020 Those aren’t angled pods I guess? Usually you can angle the filters down. I think if your insulation is working you’ll be fine Quote
Canadianshee Posted March 3, 2020 Author Report Posted March 3, 2020 Those aren’t angled pods I guess? Usually you can angle the filters down. I think if your insulation is working you’ll be fineThe filters are the 15 degree angle one. I have them pointed down and in a bit. There's about 1/4" space with rad hose. Sent from my LG-H873 using Tapatalk Quote
Jetnbyu93 Posted March 3, 2020 Report Posted March 3, 2020 I had the same issue with a set of CPI’s. I swapped the billet intakes for a set of UPPs, worked like a charm. The UPP intakes pulled the carbs down which gave plenty of room for the filters. I had a thread about this but can’t seem to locate it...Sent from my iPhone using Tapatalk Quote
