Tarrenitup82 Posted February 17, 2020 Report Posted February 17, 2020 Hello new to the page. My bike ran perfectly fine but leaked some gas from the carbs so I got a rebuild kit. I kept all the jets that were inside it because I have cool heads, vforce reeds, and t5 pipes and silencers. I’ve got 330 main and 27.5 pilot, with air box delete and tors delete. When I’m in neutral or with the clutch pulled in it runs fine and I can rev it no problem. As soon as I start to release the clutch and it begins to engage the bike starts to bog out and die, but If I rev it up and take off it will run fine and I can get into power band but as soon as I slow down and start to use a little throttle it bogs?!?! Quote
Tarrenitup82 Posted February 17, 2020 Author Report Posted February 17, 2020 Do I cleaned my carbs out again and seemed to fix the problem. I rode it up the road no issues Quote
gusto Posted February 25, 2020 Report Posted February 25, 2020 Those are big main jets for your engine. Sure your not rich? Quote
Tarrenitup82 Posted February 25, 2020 Author Report Posted February 25, 2020 15 hours ago, gusto said: Those are big main jets for your engine. Sure your not rich? Yeah I believe I am. My plugs are pretty black and wet Quote
Tarrenitup82 Posted February 25, 2020 Author Report Posted February 25, 2020 What’s jets should I run Quote
gusto Posted February 25, 2020 Report Posted February 25, 2020 I would think 280-290Sent from my iPhone using Tapatalk Quote
Tarrenitup82 Posted February 25, 2020 Author Report Posted February 25, 2020 What about the pilot? I have 27.5 right now Quote
SKEETER Posted February 25, 2020 Report Posted February 25, 2020 Sounds like the pilot needs to leave his purse home, w.O.t. and dump da clutch. Problem solved. Quote
Tarrenitup82 Posted February 26, 2020 Author Report Posted February 26, 2020 would screwing the fuel screw out do anything. I have at about 2/2.5 out Quote
Deets Posted February 26, 2020 Report Posted February 26, 2020 Where is the clip on the needle? Quote
