Try adding some compression.... It is always a good way to make some good low end power. Also i noticed that you have way too high of a gearing try running a 14 43.
if u cannot get it to the top end quickly,top end does u no good
my shee has no low end, but once my thumb pushes the throttle all the way in, im already at my top end, and pulls hard all the way down the track. try using smaller front sprockets
