Is it worth, or can domes be re-cut? Old domes are 18cc (wtf?) Stock stroke. Never ran this engine. Thinking about going 4mil.
Don't know if it makes any difference but I'm near Driveline. Haven't asked yet if they can/will do it.
What exactly is involved in getting custom cut domes?
can it be done? Yes
Is it worth it? Probably cheaper to get custom domes cut for your application.
You need to dial in the existing dome to a gnats ass on axial and radial run out, and cut the squish. Most custom domes are cut on a CNC or prototrak lathe.
much easier than dialing in existing used parts.
Call and ask.
I am a machinist by trade, I'd buy new ones.
Makes sense. Might be hard to re-set up in same lath on same day it was turned. Carpenter by trade, haven't fucked with a lath since H.S. metal shop, 50 yrs ago.
So, what exactly is a costom cut done as oppesedto off the shelf?
different squish for sure and angle depending on who you get it from.
its 55 for new domes just have DL cut them to your desired specs
Edited by Ayesully810
