Rodo5900 Posted April 17, 2019 Report Posted April 17, 2019 Okay so here’s what I got I want to know your opinion. Before I torn my banshee apart to get powder coated I had a issue were my throttle will get stuck and idle will be really higher then normal. Having to believe that maybe my throttle cable was old and worn I replaced my throttle cable took carbs out cleaned carbs out pretty much disassembled both carbs cleaned them out the whole 9 yards. So I put them back together with new reed gaskets new intake boot gaskets and now in my opinion feel like shee’s sucking air in from in between the reeds and intake boots. I will start her up she will idle for a minute once I start giving it gas and opening throttle up she begins to start creeping up slowly on the rev till she’s WOT on herself & I have to hit the kill switch. I sprayed carb cleaner around reeds and intake boots and she will start to decrease on the idle. I ordered new 28mm owl carbs new billet one piece aluminum intake (boost bottle delete) & new vforce4 reeds. Any opinions thanks. Bike has FMF power core 2 pipes and silencers Tors delete Mikuni 28mm carbs k&n filters i forgot to note jet sizes but bike has been running those jets and pilots for a year with no problems till recently that this happened. Quote
ginger Posted April 17, 2019 Report Posted April 17, 2019 put a thin layer of silicone on the reed gaskets before you put it back together. it should solve the small air leak you have there. make sure you let it dry before running. Quote
97Screamer Posted April 17, 2019 Report Posted April 17, 2019 Do a leak down test on your engine so you don't have to guess and check. Quote
trickedcarbine Posted April 21, 2019 Report Posted April 21, 2019 Air leak. Get it found and sealed up or it will melt down. Quote
