Is there a paint available that you can buy yourself and paint parts on a bike? I don't want to pay a powdercoating set up fee just to paint my hubs and brake rear brake parts. What kind of paint is durable and looks good.
Which paint can be brushed or sprayed without a spray gun?
I know this is going to sound shitty but it works and looks like powdercoat. Got this idea from when I had an airbagged minitruck and needed to clean up the looks of the bed. At wal-mart they sell cans of spray on bedliner, get one can of it and one can of clear coat spray paint.
Three coats of bed liner and three coats of clear will make your frame bullet proof.
bring them to me, ill pc them for a good deal and im in the south bay area. who did you call and what was this set up fee you speak of ? hit me up on the private message feature and well talk. later
Not a bad idea,...but that wouldn't strengthen the frame any...unless you gussett it first. I just welded up weak spots with some extra welding when I rebuilt the g/f's shee....then gave it a couple primer coats & then the Krylon touch. Looks pretty good.
there is a special 2 part epoxy paint thats meant to be really tough and hold up liek a powdercoat does
but i say jsut clean em up realy good and use a quality paint intended for painting engines or liek somebody siad that special rustoleum hammerfinish stuff whish is intended to sprray over pitted stuff
with some effort you woudl be suprised jsut hwo nice a spray can can work
unless you can score a good deal on powdercoated stuff
i just stripped my frame down and repainted it with a primer then finished it with an aluminum colored engine enamel paint from the auto parts store. I have spilled some brake fluid and things on it on accident putting it back together and I was able to wipe off the brake fluid and the paint stayed perfect. Other paints i have tried the brake fluid eats it away. It looks much nicer then i thought it would. I was going to powder coat but money was little tight and I wanted to get my bike back together and go riding plus i can always touch up any areas that get damaged without having it redone with powdercoating
