Pretty steep. I'd put it about 30lbs heavier on the front right if you have a set of scales.
Ok thanks I'll try it I race tomorrow so I'll let ya know
Sent from my SM-G930V using Tapatalk
Well I took first in the heat and second in the feature but the quad wanted to push in the front real bad I run Hoosiers in the rear but I have razor tt in the front I think I'm gonna get a set of Hoosiers for the front
What front shocks and how is the camber, castor, and toe?
Works flat track and tt front shocks don't toe is stock never really did any thing with camber and caster
this was the feature race my arms got so worn out from fighting it in the turns and I couldn't carry my speed into the turns I'm the only banshee there I'm in second the whole race the leader is running a 250r frame with 426 dirt bike motor I can pull him on the straight but I can't carry it through the turn if the link doesn't work look up Douglas Bartlebaugh and look for ATV feature at thunder mountain speedway 6/15/18
  • 9 months later...
