Cheetah 472 Domesize and Pipes / Germany
Philipp91
Hi Guys,
I'm from Germany and I'm just building a 472 cub banshee.
Daily street driven. In summertime ^^
To the engine:
- 421 Cheetah Cub
- hot rods crankshaft +4 115mm
- 2x mikuni tm 35mm
Now my question:
I want to drive 98 octane (super plus gas).
200 meters above sea level.
Which domes, psi and squeeze edge should I drive?
And which pipes are nice for the 472?
10 minutes ago, trickedcarbine said:
Is that octane a MON or RON rating?
I am 100% positive that the 98 super gas in europe is the same as our 93 pump gas.
Also OP, you have said 2 different engines in your post. Do you have a 421 or 472? Is the bore of the cylinders 68mm or 72mm?
1 hour ago, Philipp91 said:
Hi Guys,
To the engine:
- 472 Cheetah Cub
- 2x mikuni tm 35mm
Now my question:
What I would suggest doing to get the best answer, is email someone like Redline Racing (http://redlineracing.biz/) or FAST (http://farmandsandtoys.com/ocart2/index.php) and give them your info, make sure to let them know the fuel you want to run (and that it is measure by the RON). They will give you the best answer as they builder a few of these motor and know them better than the average member on here.
