You may not use the banshee as much. Be careful
Sent from my SAMSUNG-SM-G891A using Tapatalk
I only put 20 hrs on the shee of ride time this past summer. Mainly cuz i worked insane over time all year, but yeah. I hear u haha
Sent from my LGMS210 using Tapatalk
Coat rack bansheea3cceefab554cec9ab08b449c744d218.jpg3b98be9ffafa573a28224fa0e990783a.jpg
  • Like 1
Just sell me that pos u call a coat rack and be done with it lol
Edit: On second thought u gunna need 4 treverton in 2018 so nvm
Everything done to the shee.
98 Shee, lightened frame to 30lbs, 2+1 a arms, lowered 2" in rear, stock bore and stroke, Wiseco Pro-Lite's, trued crankshaft, Dune Ported aftermarket cylinders, stock head, Vforce4 reed cages, 28mm bored stock carbs, K&N style pod filters w/ outerwears, full Pro-Circuit platinum exhaust, adjustable timing plate set to +4, dynatek ignition, stock flywheel, stock gearing, 22" rear tires, jetting 320 mains, would have to look what the pilot is again.
Maybe add some compression? Can help with bottom end some.
I would say keep the 22", the extra inch of ground clearance in trails is nice to have. Just a smaller front sprocket on, way cheaper than new tires.
For sure
Also get some t5s that will help
T5s r the best i WILL have them on every bike. There is a 5 on the end for a reason. That means xtra 5 pounds of torque
Well then T6>T5
