Stephen_banshee01 Posted June 26, 2017 Report Posted June 26, 2017 (New top end stick boreand crank fmf fattys with powercore 2s pro flow I take boyesen dual stage reeds boost bottle stockcarbs with tors delete elevation is 217' above sea level). Hopefully someone can help I just wanna be sure I have the right jetting in my quad it seems as if it cuts out when I'm really on the gas like it's running lean? I don't know but I'd like to know what jets I should run and myneedle height and my mixture screw. I do not know what size are in my carbs right now but maybe someone can help quad runs great just that little problem. And it also feels like it runs way hotter than it did before I rebuilt I thank you! 01 banshee stock stroke and bore all engine mods posted above. Quote
bluebanshee98 Posted June 26, 2017 Report Posted June 26, 2017 Can't tell you what jets to use if you don't even know what kinda carbs is on there Sent from my iPhone using Tapatalk Quote
Stephen_banshee01 Posted June 26, 2017 Author Report Posted June 26, 2017 It says stock carbs and I don't know the jet size that's in there sorry to cause any confusion both carbs are stick with no tors Quote
gusto Posted June 26, 2017 Report Posted June 26, 2017 Your going to want to start big and go smaller. I would start with a 290 main jet. Buy 290 and start leaning out. Buy like 5 sets of jets. Pilot will most likely be 27.5 use youtube for carb sync Quote
