Okay guys, I'm a noobie to two-stoke atv engines.  I have a friend's 1996 Banshee that I'm working on.  They tried to put a twist throttle on it and couldn't get it to work.  Then they re-install the stock thumb throttle on it and jacked it all up.  The bike wouldn't idle and had no power when riding it.  I did some research and found the plungers were swapped on the carbs when I was syncing them.  I fixed that and adjusted the idle to OEM Spec. Idles and runs a lot better.  but now it will runs good then suddenly the rpm's will take off uncontrollably and I have to stall it the to kill it to kill the engine. The Engine off switch would not kill it.  The only thing I can think of is a crack in the intake boot or air leak after the carb, but I didn't see any.  Oh, and yes unfortunately it does have the TORS system on it but wires are cut on them.  Already recommended to the owner we put a TORS removal kit on it.   Any ideas what it could be?
When it takes off it is a lean run away. When that happens, kill the ignition and open then throttle all the way.
Do a leak down test to check for air leaks.
