Hi guys
So my current setup is a long rod crank and 795 Pistons,
Since the 795 only go up to 2mm oversize I'm just curious how one would overcome the long rod +5mm over 66mm bore ?
Or is 66mm the max bore on Std barrels , and anything higher specially designed barrels ?
Blaster piston
Thanks but blaster Piston does not have offset wrist pin for +5mm rod ?
Or are the jugs designed to accommodate the Long rod ?
