97Screamer Posted April 20, 2017 Report Posted April 20, 2017 Has anyone ever personally put YFZ450R rear hubs on a banshee before? I know the YFZ450 fit so I'm specifically asking about the "R" model. I believe they are wider than stock banshee but with an adjustable lonestar axle would this matter? I ask because I can get a good deal on a set of used billet lonestar hubs but lonestar tells me they are different part number and doesn't know if they'll work. My online research is that the splines and bolt pattern is the same, just the width/offset is different? Can anyone confirm this? Any issues with that I'm overlooking? Anyone insight is much appreciated! Quote
97Screamer Posted April 20, 2017 Author Report Posted April 20, 2017 Thank you for the fast reply! I assume you had no issues using the YFZR hubs? Quote
97Screamer Posted April 20, 2017 Author Report Posted April 20, 2017 None, slide right one, gained like 1.75" to my width over stock banshee hubs. Thank you that's exactly what I needed to know! You're the man! Quote
spurdy Posted April 20, 2017 Report Posted April 20, 2017 ^^^^over achiever. Lol! Sent from my iPhone using Tapatalk Quote
