erbilabuc Posted December 7, 2003 Report Posted December 7, 2003 I did the Race Logic porting kit myself. Everyone says that going to bigger carbs give you more power! Is this true? I am still on stock 26's and I can smoke piped 450's. Someone hollah at me about this. Quote
Dragg-on Posted December 7, 2003 Report Posted December 7, 2003 Stock 26s can go a long ways, Ive got 34pjs on my methanol drag shee, but I would definately stay with 26s for gas, the DYNO showed only a +2hp differance on my ported shee on gas with 34s(ask yourself if its worth it). Large carbs payoff when you run alky! Quote
Justintoxicated Posted December 8, 2003 Report Posted December 8, 2003 I would ask the guy that poted your Banshee if he set you up for larger carbs Quote
Blue Duece Posted December 8, 2003 Report Posted December 8, 2003 Stock 26s can go a long ways, Ive got 34pjs on my methanol drag shee, but I would definately stay with 26s for gas, the DYNO showed only a +2hp differance on my ported shee on gas with 34s(ask yourself if its worth it). Large carbs payoff when you run alky! im with dragg..if you had to open your 26's up to there max to feed the intakes id say go with larger carbs other wise youd end up choking a 34 down and what would the point of that be..i run 34's but my port will support the fuel....and you really have to know porting to get it to swallow that much fuel chances are your running a mild port or it wouldnt run good with 26's Quote
Screamin_Banshee Posted December 8, 2003 Report Posted December 8, 2003 I agree, the stockers will go alot further than ppl give them credit for! That are actually a pretty damn decent carb...If you are lookin for a tad more, jsut get them bored to a 28mm, might help a little. Just my $.02 Quote
H300F Posted December 9, 2003 Report Posted December 9, 2003 Blue Deuce, did you get your motor running yet? how do you like it? do the 34s work real good on it? Quote
Blue Duece Posted December 9, 2003 Report Posted December 9, 2003 Blue Deuce, did you get your motor running yet? how do you like it? do the 34s work real good on it? yes im posting a review in about 5 minutes it will be in the review section, the 34's are sweet really really nice......take alook Quote
