Banshee 400 Posted April 4, 2017 Report Posted April 4, 2017 Just got my banshee back together and it won't start it's got spark and fuel and not sure what else it could be out new plugs in I believe the timing may be off with this cause it not to start? If I let it sit a while then go kick it will sound like it wants to turn off but nothing help!!! Sent from my iPhone using Tapatalk Quote
sleeper06 Posted April 4, 2017 Report Posted April 4, 2017 have you pressure tested the motor after assembly. If it's not tight it won't pull fuel properly in order to feed it during start up. Give it a quick squirt of starter fluid while holding slides open with throttle, close slides and kick . If it fires you have a fuel delivery issue weather it's carbs or air leak causing weak pulse Quote
Banshee 400 Posted April 4, 2017 Author Report Posted April 4, 2017 have you pressure tested the motor after assembly. If it's not tight it won't pull fuel properly in order to feed it during start up. Give it a quick squirt of starter fluid while holding slides open with throttle, close slides and kick . If it fires you have a fuel delivery issue weather it's carbs or air leak causing weak pulse Sent from my iPhone using Tapatalk Quote
Banshee 400 Posted April 4, 2017 Author Report Posted April 4, 2017 have you pressure tested the motor after assembly. If it's not tight it won't pull fuel properly in order to feed it during start up. Give it a quick squirt of starter fluid while holding slides open with throttle, close slides and kick . If it fires you have a fuel delivery issue weather it's carbs or air leak causing weak pulse Never took the engine apart it was running fine before, I did frame work and cleaning but now the spark is weak I did change stator and it has a adjustable plate now could the timing be off? Or could I have a grounding issue? Sent from my iPhone using Tapatalk Quote
sleeper06 Posted April 4, 2017 Report Posted April 4, 2017 Also if it's a Ricky stator scrap wire set up that could be the issue . I've had three back to back rite out of box not work, hope that's not the case cuz I had a hell of a time getting a refund. They were trying to tell me my bike was blowing the stator out Quote
Banshee 400 Posted April 4, 2017 Author Report Posted April 4, 2017 What frame works did you dopowder coating all new bearing bushing new a-arms Sent from my iPhone using Tapatalk Quote
Jereme6655 Posted April 8, 2017 Report Posted April 8, 2017 You check to make sure the choke tube made it back in between the carbs when you pulled the frame down to work on it? All grounds good? Quote
