Ayesully810 Posted March 12, 2017 Report Posted March 12, 2017 1. Can I leave the steering stem bearing in my frame and get it powder coated and have it not be ruined? If not then how do you remove it? 2. Wtf is this tab? I wanna cut it off Sent from my LGMS210 using Tapatalk Quote
sleeper06 Posted March 12, 2017 Report Posted March 12, 2017 Old tors box tab. Take bearing out and make sure you tell the powder guy to really protect those threads and bearing slots. If not you will hate yourself for it. Tell them protect it before they blast it, most pc guys use real course media and I've seen it destroy threads on a few occasions.any other question reach out Quote
hoppedupandcutdown Posted March 12, 2017 Report Posted March 12, 2017 Pull the upper seal, clean out the grease, use a 1.25" or 32mm headed bolt (or a flywheel remover with the large hex body) to remove the inverted nut. The bearing should just slide up and out. Cover the VIN too, for blasting Quote
Ayesully810 Posted March 12, 2017 Author Report Posted March 12, 2017 Thanks fellers. Appreciate it Sent from my LGMS210 using Tapatalk Quote
Ayesully810 Posted March 12, 2017 Author Report Posted March 12, 2017 Old tors box tab. Take bearing out and make sure you tell the powder guy to really protect those threads and bearing slots. If not you will hate yourself for it. Tell them protect it before they blast it, most pc guys use real course media and I've seen it destroy threads on a few occasions.any other question reach outThanks carl nvm that pm i sent u i figured it out Sent from my LGMS210 using Tapatalk Quote
