yamashee02 Posted March 4, 2017 Report Posted March 4, 2017 banshee was running then flywheel got loose now it just backfires . I got it to start once after the flywheel came loose . When it did start had a small mid range bog but would rev out . The bike has twist throttle and has air screws drilled in the carbs Quote
rjdgriff Posted March 4, 2017 Report Posted March 4, 2017 Check your pickup gap? Sent from my iPhone using Tapatalk Quote
sheerider11 Posted March 4, 2017 Report Posted March 4, 2017 Pull the flywheel and see if your key is good. Possibly way out of time 1 Quote
sangheraent Posted March 4, 2017 Report Posted March 4, 2017 if flywheel came loose theres no way the key survived. put a brand new key in there. Quote
rubberneck Posted March 4, 2017 Report Posted March 4, 2017 Flywheel key, or damaged/dislocated pickup or damaged stator or damaged flywheel, pull it all apart and start inspecting Quote
Scrubby Posted March 5, 2017 Report Posted March 5, 2017 Did you mean idle screws? if you cant explain what your adjusting you probably shouldnt be adjusting it. till you know what its called and what it does. Quote
rjdgriff Posted March 5, 2017 Report Posted March 5, 2017 Did you mean idle screws? if you cant explain what your adjusting you probably shouldnt be adjusting it. till you know what its called and what it does. shut up Sent from my iPhone using Tapatalk 1 Quote
