yamashee02
Everything posted by yamashee02
  1. Ok have a set of cylinder bore .20 over would like to get 150, out of them, also have a prodesign coolhead wit 21 cc domes also like to get 150 Just message me for pics
  2. Well fellas I was hopi g so.eone would have a good deal on some works shocks and possible some DMC silencers hmu cash I. Hand
  3. It' the left side that smoking more
  4. Well fellas I got her to where shee will start after 4 or 5 kicks with choke on, the right exhaust isn' smoking like the left is and my right carb is leaking gas outta the over flow on the bottom of the bowl, is there a reason my right isn' smoking the same as the left , thank you for ur help
  5. No major work at all just just .20 pro stock pistons is all coolhead 21cc domes fmf exhaust for timing plate and that's it beside aftermarket cdi box
  6. Well I'm running a br8es plug but my uncle told me.to try and take the timing back from +4 to.0 well when I check it out looked like my cousin who put it on there for me while I was at work put it on plus 7 may have just been 6, ran the bike all day that day and it ran great but now it' a bitch to start and when it does the right exhaust is backfiring I put it back down to plus 4 thinking that would help it start but it still a bitch to start her actually haven't even got it started back at plus 4 got aggravated and had to quit for the day
  7. Klotz 32 to 1 93 octane
  8. Ok I got a coolhead 21cc domes, and pro stock pistons, I tried to start her and the right cylinder backfired had to roll start her , lots of like carbon and gunk inside on the domes and carbon on pistons, my idle screw fell out somehow would that have cause it I ordered a new one and put it in
  9. Where r u located? Also what type of works are they? Sent from my SM-G900R4 using Tapatalk
  10. What do want for them ? Sent from my SM-G900R4 using Tapatalk
  11. Hey fellas was wondering if any of u guys some front shocks for sale working on a slight budget so was looking more towards works any help would be greatly appreciated
  12. Ok bro yea I just pluggd those up and now I see that I'm losing in coolant from the bottom of the motor now t leaking like crazy pouring really from one bolt , also where to get that tapatalk do I have to download it??
  13. Tried to take a pic but it said it was to big
  14. Ok fellas I just got my my studs my new orings and all that got the coolhead on and when I went to fill it with coolant it came pouring out the side of the cylinders , I don' ever rememer there being a bolt in those holes on both sides
  15. O and have pics just let me know if interested
  16. I have a pro design cool with 18 cc domes I need to trade for an axle preferably a plus 2
  17. Nah bro I don't
  18. OK I got the fuel to stop coming out the over flow.. I know u said I need 27.5 pilots... And I found something out if I put my hand over the left carb with the choke pulled it starts without ether. It idles really high when choke is in, idles normal half way out and almost dies when pulled all the way out... Would those pilots cause that
  19. OK I got the fuel to stop coming out the over flow.. I know u said I need 27.5 pilots... And I found something out if I put my hand over the left carb with the choke pulled it starts without ether. It idles really high when choke is in, idles normal half way out and almost dies when pulled all the way out... Would those pilots cause that
  20. OK I got another question the left carbs bottom overflow is leaking gas.. already clean carbs they spotless
  21. yea i have stock pilot needle
  22. ok here is what all it has fmf fattys twist throttle with tors removal advance timing 4 degree and pro flow intake and 270 jets.. ok the only way i can get it to start is when i spray ether into the carbs when it does start it doesn't wanna idle , got to keep giving it gas to keep it running. still has like a small bog in it when u give it small amount of gas but when u open it up it is fine. please help
  23. banshee was running then flywheel got loose now it just backfires . I got it to start once after the flywheel came loose . When it did start had a small mid range bog but would rev out . The bike has twist throttle and has air screws drilled in the carbs
  24. Just take the plastic plug apart
  25. Ok I got a 02 shee I put new stator cdi coil. But still no fire if I take the plug caps off it will shock me if I hold both together but If i separate and hold one wire at a time nothing.. Also I removed the tors when I put on twist but I was reading there was a small black box I needed to make sure is disconnected to as well right.... Its got me lost...
