I'm sure it's better than what I have.
Look for a set of Lonestar +2+1 arms an some decent shocks an you will be far better off than cobbling together a yfz front. Yfz is for yfz.
Sent from my SCH-I545 using Tapatalk
I have an entire front end off an 06 Yfz450 I was going to put on mine but will probably never get around to it. It has the arms, tie rods, spindles, hubs, rotors, calipers and shocks, all in good-great shape. There are also 3 extra arms in good shape with damaged ball joint threads, could be nice spares if you changed the ball joints. I'd take $400 plus shipping for everything, if you're interested let me know and I'll snap some pictures.
  • Like 1
Where do you live?
. Ya and then I still have stock brakes & coils
Put the yfz shocks on the Alba arms then? Would at least get ya headed in the right direction. Pick up a set off eBay for around $100.
  • Like 1
YFZ shocks are ~2" longer than stock banshee shocks, not a good idea on Alba arms IMO. If you wanted to go that route buy the Full flight +3 +1 arms designed for a banshee with YFZ shocks.
  • Like 1
I don't think any of this is a good idea. Just trying to have him pick the least ridiculous idea.
I'd do alba arms and pick up a decent set of used works or something like that. Should be able to be under $500 if he is patient
  • Like 1
Works shocks are a cheap route. If your a little guy maybe pick up a decent used set close to your weight.
Sent from my SM-S820L using Tapatalk
