About wheelies
maggdog
My old Ds 650 was the easiest thing I've been able to ride out. So fucking heavy it took a whole gear wound out to lift it....then she just floated through the other 4 gears.
Also the biggest piece of shit at anything else! Banshee just has abrupt power harder to balance up initially.
Sent from my SM-S820L using Tapatalk
Back when I was a wheelie boy we used to go by exits on the parkway. I did close to 3 miles a few times then it gets boring. This was on a 4mill stock cylinder with my wheelie port job ,+4 timing,mull engineering pump gas head. Fmf fatties , stock carbs, rear brakes controlled off handle bars. I ran the idle higher than most and the clutch cable a Lil more slack than most to make slow wheelies a lot easier. Slow wheelies require a good feel for the clutch and the ability to operate it with one finger in unison with the rear brake
  • Like 1
