BlkBansh05 Posted January 5, 2017 Report Posted January 5, 2017 05 Banshee with stock stator. I currently have 6.5w (each light) mr16 leds in trail tech housings mounted at the factory headlight locations. Tonight I ordered a 10" 40w led bar to mount either on the bars or front bumper somewhere. 2 questions.... 1. Is the stock stator powerful enough to power all lights mentioned? 2. Can I just splice in the light bar to the current power source/wiring that is feeding the stock headlights? I've been reading about maybe needing a battery or rectifier but not sure what to do. Thanks Quote
Keno Posted January 5, 2017 Report Posted January 5, 2017 1.Stock stator is good to about 75W, so you're fine. 2. Yes, but ideally no. At the very least a small bridge rectifier will keep the leds from burning out (bike leads to AC, +- to leds) . Or get a DC conversion from JD http://www.jdscustoms.com/product/jl-engineering-complete-dc-conversion-kit/ But everything has been discussed recently so search around. Quote
