BlkBansh05
Everything posted by BlkBansh05
  1. 05 Banshee with stock stator. I currently have 6.5w (each light) mr16 leds in trail tech housings mounted at the factory headlight locations. Tonight I ordered a 10" 40w led bar to mount either on the bars or front bumper somewhere. 2 questions.... 1. Is the stock stator powerful enough to power all lights mentioned? 2. Can I just splice in the light bar to the current power source/wiring that is feeding the stock headlights? I've been reading about maybe needing a battery or rectifier but not sure what to do. Thanks
  2. Thanks for the replies and entertainment. I ended up going with a chinese rad, vitos impeller, new gaskets/seal and engine ice. Will report back. Thanks again.
  3. Mainly Glamis...lots of open terrain.
  4. Looking for opinions on the "perfect" cooling system for my bike. After 2 weeks of researching I can't seem to make up my mind. Looking for field tested feedback. Thanks (example: Toomey rad, engine ice, Pro Design Impeller, Cool Head etc)
  5. Thanks a lot. Very helpful. That FB front end looks good on that thing! Keep it.
  6. That would be great, thank you. If its not too much trouble could you clarify what had to be done to the radiator to correct fitment? Appreciate your time.
  7. Thanks for the heads up on the more affordable route. Can you provide the seller you have been using? Glad to hear no issues. Thanks again.
  8. Will be purchasing one of the $100 eBay oversized radiators and was wondering if it will fit with my FullBore front end. I understand the radiator mounts themselves are the same but I'm concerned with the actual clearance between the radiator and the plastics/grills. It seems pretty close already with the stock one. Anyone running this combo and can give me some feedback? Appreciate it.
  9. Haha...well I guess that's one way of eliminating my wheel play, but I'm good.
  10. Just a quick snug. I will take a close inspection tomorrow. Not sure if this matters but I have a Roll Design LT front end. Are they known for any weird quirks that you know of? Overall, I've been very happy with it but I thought I'd ask.
  11. I noticed a small amount of play on my front left wheel after an overnighter at Superstition a few weeks back. With the bike on a stand (front end fully dropped out) I can feel a slight "back and forth" on the front left wheel (my hands are positioned at 12 o clock and 6 o clock when checking). I have since installed new upper and lower ball joints and wheels bearings. The front right wheel feels like it was built and installed by the hand of god..absolutely no play and solid as can be. However, the left side still has a minimal, but noticeable amount of play. I guess my questions is.....what other areas on my front end could cause this symptom? I have checked the tie rod ends, arm mounts, shock mounts...even snugged everything down and still, no luck. Pretty puzzled. Let me know your thoughts. Thank you
