Clutch/clutch lever issues
  • 2 weeks later...
Update: I've replaced the clutch cable and still have the problem. I'm told it is a new clutch which I believe for 2 reasons, one being that it's a fresh motor, and 2, the clutch is EXTREMELY grabby like it isn't fully broken is yet. Once it starts grabbing there's almost no movement at all on the perch before the clutch is fully engaged.
Anyways, so I know it's not the cable, or the perch, and I'm guessing it can't be the pressure plate either because of how the clutch feels unless there's an adjustment on the pressure plate that I don't know about. That leaves the actuator, hub,basket, and adjustment? What do I do to check these things? Also, I have changed my transmission fluid very recently, like a week ago (about 5 hours total ride time), can I reuse it or do I need to go buy new fluid?
  • 2 weeks later...
Theres a ajuster in the middle of your preasure plate. That solved my problem and it wasthe same thing that happening to u. Also make sure your clutch basket and the gear the gear thats on the back of it dont have play, but i wouldent think that would make it jump into gear with the clutch in. I bet it just needs to be ajusted at the ajuster on your preasure plate.
Edited by Yamahafan#1
