I'm running full fmf gold series sst.
At 659 elevation
300 main jet
25 pilot jet
32:1 mix
Stock mikunki carbs
Stock pistons.
Do you think if I run 42:1 mixture it will be better or even adjust the air/mix screw? I don't know how to tell what position the needle is at so that could be it to. But when I was ripping it seems to be getting gas well, no bogging. I was also going to 27.5 but it starts fine and idles fine so idk if it would matter please help.
Sent from my LG-H900 using Tapatalk
When was last time carbs were cleaned AND the floats set ?
Were these plugs run like in doing a plug chop? Or were you just riding around?? Big difference !!
Single air filter ??
Why would you want to use less oil ??
Carbs were cleaned over the weekend and I'll have to look up how to set the floats I have never done it. I mean I got to sixth pinned but I didn't shut it off right away I rode it home like a qrt. Mile after. And I do want to use more oil so I dot fry my pistons. Sorry newbie post lol
Pic of the first plug looks good.
Sent from my ZTE T84 using Tapatalk
So maybe I just have to go over my carbs and make sure everything is the same ?
