maggdog Posted June 27, 2016 Report Posted June 27, 2016 Is normal this humidity or wet of gas betwen carb and intake? Has in both boots Quote
Power_Man Posted June 27, 2016 Report Posted June 27, 2016 this after a ride when warmed up, or cool? Quote
maggdog Posted June 27, 2016 Author Report Posted June 27, 2016 Now are cool, but i think also has this after ride Quote
maggdog Posted June 27, 2016 Author Report Posted June 27, 2016 Has a difference between cool or after ride warmed up? Quote
Power_Man Posted June 27, 2016 Report Posted June 27, 2016 it looks like condensation. after you ride, if would probably disappear if condensation. where are you located and temps? touch it with your finger, then smell it. kinda like the what you do with a girl you bring home from the bar. sniff it before you lick it. Quote
bigweav81 Posted June 27, 2016 Report Posted June 27, 2016 Your actuator arm is beat the fuck up lol. How did that happen? Sent from my SM-S820L using Tapatalk 1 Quote
maggdog Posted June 27, 2016 Author Report Posted June 27, 2016 Your actuator arm is beat the fuck up lol. How did that happen? Sent from my SM-S820L using Tapatalk Shit. You have all right. It comes when bought the banshee i thought that was normal but i compare with other and not lol. The stupid mechanics of this atv bent. Thanks for advice i'll fix that Quote
bigweav81 Posted June 27, 2016 Report Posted June 27, 2016 Shit. You have all right. It comes when bought the banshee i thought that was normal but i compare with other and not lol. The stupid mechanics of this atv bent. Thanks for advice i'll fix thatIf it works, it works. F.A.S.T sells them at a decent price. Check them out. I figured you welded your ball to your push rod, and was determined to make it move lol. Sent from my SM-S820L using Tapatalk Quote
maggdog Posted June 28, 2016 Author Report Posted June 28, 2016 it looks like condensation. after you ride, if would probably disappear if condensation. where are you located and temps? touch it with your finger, then smell it. kinda like the what you do with a girl you bring home from the bar. sniff it before you lick it. I ride a few hours and after ride still and smell to gas Quote
Scrubby Posted June 28, 2016 Report Posted June 28, 2016 float bowl screw is all malled up too, make sure its not leaking fuel Quote
kawa110 Posted June 28, 2016 Report Posted June 28, 2016 Replace the reed cage gaskets.... Sent from my iPhone using Tapatalk Quote
RIPPIN' IT UP Posted June 28, 2016 Report Posted June 28, 2016 I can't see any breather hoses from the carbs, if there missing fuel will end up everywhere, always get a bit of fuel run out my breathers onto the casings when riding. Sent from my Z6 using Tapatalk Quote
