robert0762 Posted June 15, 2016 Report Posted June 15, 2016 All prices are for parts only. Shipping will be added. We all know what flat rate usps boxes cost. Will do package deals.will sell whole lot . yfz450 spindles hubs rotors 40 one hub is missing spacer in between bearings banshee hub w/rotor 15 clutch fibers and steels two full sets one stock the other ? 10 head 10 kicker gear 15 idler gear 10 crank gear 10 clutch nut washer and bearing 20 sprocket nut and sleeve 10 crank nuts both sides and keys 20 trans clips 5 presure plates 15 clutch hub 15 dual stage reeds 30 clutch arm 10 sprocket and hub 15 brake hub 15 cylinders 65.00 need a bore 80 shifer 10 light and run switch 20 nuetral sw cover 5 shift shaft 10 shock good 50 water pump cover 5 lights for parts 10 k and n filters for stock or 28 mm carbs 15 upper left a arm 15 rad cover w panty dropper 20 front brake master cylinder 10 rad hoses all for 10 rear linkage 40 steering stem mounting blocks 15 tail light 10 rear brake lt switch 10 clutch cover 20 flywheel cove 10 tie rods stock 10 foot pegs w bolts 25 throttle 25 front brake line lower one 5 two stock frames 100 each carbs stock 50 for all clutch springs heavy normal and stock 15 for whole box front fender supports 20 timing plate 5 coil missing one cap 10 rear chain guide 10 443 617 3865 text w any questions rob paypal is [email protected] leave a note saying what its for 2 Quote
robert0762 Posted June 15, 2016 Author Report Posted June 15, 2016 Clutch springs sold Sent from my SM-G900V using Tapatalk Quote
robert0762 Posted June 15, 2016 Author Report Posted June 15, 2016 (edited) Will trade for a good seat foam or whole seat just need good foam Edited June 15, 2016 by robert0762 Quote
robert0762 Posted June 15, 2016 Author Report Posted June 15, 2016 Cylinders sold Sent from my SM-G900V using Tapatalk Quote
slag_350300 Posted June 15, 2016 Report Posted June 15, 2016 I texted you the other day about parts ? Quote
robert0762 Posted June 15, 2016 Author Report Posted June 15, 2016 I texted you the other day about parts ?Text me again please Sent from my SM-G900V using Tapatalk Quote
robert0762 Posted June 17, 2016 Author Report Posted June 17, 2016 (edited) Rear brake caliper sold Sent from my SM-G900V using Tapatalk Edited June 17, 2016 by robert0762 Quote
robert0762 Posted June 17, 2016 Author Report Posted June 17, 2016 Bump Sent from my SM-G900V using Tapatalk Quote
Presidentlincoln Posted June 19, 2016 Report Posted June 19, 2016 still got the clutch hub Sent from my SM-G920V using Tapatalk Quote
robert0762 Posted June 19, 2016 Author Report Posted June 19, 2016 Yes I have clutch hub Sent from my SM-G900V using Tapatalk Quote
Shee_fast Posted June 19, 2016 Report Posted June 19, 2016 Do you have a flywheel? Sent from my LGLS990 using Tapatalk Quote
robert0762 Posted June 20, 2016 Author Report Posted June 20, 2016 Do you have a flywheel? Sent from my LGLS990 using Tapatalk No flywheel Sent from my SM-G900V using Tapatalk Quote
robert0762 Posted June 21, 2016 Author Report Posted June 21, 2016 Throttle sold Sent from my SM-G900V using Tapatalk Quote
Scrubby Posted June 22, 2016 Report Posted June 22, 2016 FYI, Ceet racing sells seat foams, if you don't find one. medium is stock feel. Just had mine done, liked the cover and foam, but not the install. Quote
