Presidentlincoln
Presidentlincoln's Achievements
  1. so you won't take any less then 280? Sent from my SM-G920V using Tapatalk
  2. I'll give you 220 Sent from my SM-G920V using Tapatalk
  3. will you take any less? Sent from my SM-G920V using Tapatalk
  4. ok so I took the wires out of the coil and I still get nothing is that was an open circuit is, like something shorted out and something isn't touching anymore I'm far from an electrician Sent from my SM-G920V using Tapatalk
  5. just rebuild the sheet and currently has weak spark if any like I'll get something every 5 kicks or so so here's what I've tested so far Ignition coil red and green wire 19.3 ohms pick up coil red white and green white wires 116.8 ohms lighting coil black and yellow wire 1.3 ohms primary coil the orange and black wire 1.3 and I could not figure out the secondary coil connection I wasn't getting a reading no matter what way I tried I read you go plug end to plug end and plug end to ground idk just looking for some help I'm leaning towards my coil I think it should be like .3 but I'm not sure any input is more then welcome Sent from my SM-G920V using Tapatalk
  6. got one Sent from my SM-G920V using Tapatalk
  7. not worried about the brand just looking for a good shape basket Sent from my SM-G920V using Tapatalk
  8. yeah ill do that thanks Sent from my SM-G920V using Tapatalk
  9. is any play bad or is there a tolerable allowance Sent from my SM-G920V using Tapatalk
  10. it's a stock Basket new one is in the future but at the bottom of the list should there be any play between the basket and the drive gear I'm assuming my cushions are shot but I guess what I'm asking is how bad is bad Sent from my SM-G920V using Tapatalk
  11. still got the clutch hub Sent from my SM-G920V using Tapatalk
  12. ok I'll build a leak down tester tomorrow seems easy enough bought a tach and I'll get that other tool eventually too thanks Sent from my SM-G920V using Tapatalk
  13. yea tors has been eliminated and no on the rest of that stuff I just built my motor and haven't even gotten it in the bike yet Sent from my SM-G920V using Tapatalk
  14. it's not ported that's the next investment and no I didn't that's how it came and the person that had it before me might not know as much as he thought he did about working on shit Sent from my SM-G920V using Tapatalk
  15. I'm 1000 ft above sea level, bored .050 over pro x piston, toomey t5s, vf3, cool head with 21 cc domes, chariot cross over intake, +4 timing no air box lid. what I have now is a 25 pilot and the main is 340 that seems huge just looking for some input thanks Sent from my SM-G920V using Tapatalk
