need some help!
hello i recently just bouight a 2000 banshee with dual pro circuit exhausts  i put fresh fuel in it today after i cleaned the carbs and it fired right up! now the problem is that the left exhaust does not get hot like the right side  they both smoke about the same and both slides move equally and body have any advice on what this could be??
Edited by cumminsguy95
Start with basiç maintenance. Clean filter, carbs one at a time, new plugs. Write down what the jet numbers are and needle position for future reference.
Ohm plug caps separately, trim 1/4" from wire, install with bit of dielectric grease.
Check pick-up gap .018" make sure nubs are free of rust.
What do current plugs look like?
Switch plug wires and see if it switches. Done a compression test?
Reeds could be wore out.. sometimes even look ok. Swap them and see if it follows. Jet could have got clogged from something in fuel line.
