cumminsguy95 Posted April 9, 2016 Report Posted April 9, 2016 (edited) hello i recently just bouight a 2000 banshee with dual pro circuit exhausts i put fresh fuel in it today after i cleaned the carbs and it fired right up! now the problem is that the left exhaust does not get hot like the right side they both smoke about the same and both slides move equally and body have any advice on what this could be?? Edited April 9, 2016 by cumminsguy95 Quote
Larry's Shee Posted April 9, 2016 Report Posted April 9, 2016 Start with basiç maintenance. Clean filter, carbs one at a time, new plugs. Write down what the jet numbers are and needle position for future reference. Ohm plug caps separately, trim 1/4" from wire, install with bit of dielectric grease. Check pick-up gap .018" make sure nubs are free of rust. What do current plugs look like? Quote
camp0429 Posted April 9, 2016 Report Posted April 9, 2016 Stock carbs? If so the most common problems is choke tube missing, slides switches, or float bowls switched. Happens all the time Quote
Surfrjag Posted April 10, 2016 Report Posted April 10, 2016 Switch plug wires and see if it switches. Done a compression test? Reeds could be wore out.. sometimes even look ok. Swap them and see if it follows. Jet could have got clogged from something in fuel line. Quote
cumminsguy95 Posted April 10, 2016 Author Report Posted April 10, 2016 Stock carbs and the plugs look like a darkish coffee color Quote
