Larry's Shee Posted June 11, 2016 Report Posted June 11, 2016 Was actually going to call you, but got busy. As to the top end not cleaning out, could try removing snorkle from air box lid, if it gets better then try removing the lid. Still unsure why it would have had the larger main as only mod is the reeds. Quote
motoman011 Posted June 11, 2016 Author Report Posted June 11, 2016 Mains were 200 or 210, I pulled one just to check, it's a slight issue, I believe it's not lean enough on the air screws so I'm gonna back out an 8th and go from there, very slight issue, if they were 240 it would fall flat all over without pipes, it's just a tiny throttle response issue about a quarter to mid, I may adjust needle clip positions if air screw adjustment doesn't clean it up. Quote
motoman011 Posted June 14, 2016 Author Report Posted June 14, 2016 Just sent you a message, I'm gonna dump the snorkel, which I intended on doing, see where it is, if it's still not right, I'll remove the lid, should be ok with the pro design filter and adaptor, if it's still not enough, I'll throw the lid on and out on the air screws an 8th and go from there, seems rich off throttle to just below half or a little less so I'll lean it a tad if increasing the air flow doesn't make the difference, should be fairly simple. Quote
