liljake Posted March 18, 2016 Report Posted March 18, 2016 Alright so I finally decided to tear down my shee and build it this winter and its comin together pretty well and i need help in knowing where to start with my jetting the mods i got are... Power lid k and n filter and another k and n filter in the box 28mm pwk carbs which is where i need help 4 mill 115 long rod hardcore mx port job from herrjugsracing 20cc domes cool head dmc 916s im planning on buying next week or should stay with fmf fattys pump gas 92 or 93 octane 32:1 amsoil Btw this is my first post on here ever if i did anything wrong or posted this in the wrong spot. my bad Quote
dirtydownunder Posted March 19, 2016 Report Posted March 19, 2016 ask kevin, he should get you in the ballpark. maybe around 148-155/45-48 around 70 temps and sea level never tried the 916s, a few people prefer them over the fmf's Quote
Surfrjag Posted March 19, 2016 Report Posted March 19, 2016 you should also consider checking the squish clearance.. those carbs with that setup should be around 48 pilot jjh or n68a needle and 155 main jet. Quote
hercalmighty Posted March 19, 2016 Report Posted March 19, 2016 Are you running a spacer plate or cut domes? If you are running cut domes, 20cc domes are too small for 93 octane. You would need 23-24cc domes Sent from my VS990 using Tapatalk Quote
liljake Posted March 19, 2016 Author Report Posted March 19, 2016 Ya they are cut domes thanks guys for the info. Quote
liljake Posted March 19, 2016 Author Report Posted March 19, 2016 I did talk to Kevin tho a few weeks ago he said I should go with the cut domes and not a spacer plate Quote
hercalmighty Posted March 19, 2016 Report Posted March 19, 2016 Ok. So if they are cut and you want to run pump gas, you will need different domes Sent from my VS990 using Tapatalk Quote
liljake Posted March 19, 2016 Author Report Posted March 19, 2016 Should I use the 60 thousandths or the 20 thousandths gasket then if I get bigger domes Quote
hercalmighty Posted March 20, 2016 Report Posted March 20, 2016 You would have to check your squish and compression Sent from my VS990 using Tapatalk Quote
liljake Posted March 20, 2016 Author Report Posted March 20, 2016 Ok I know before without the stroker in it but I had 20cc domes in it that were not cut obviously it was stock stroke but I was at 165 psi and I ran pump gas 92 or 93 and it ran great Quote
dirtydownunder Posted March 20, 2016 Report Posted March 20, 2016 160+ is close to the limit with 94 pump. I run 170 on pump but with no added timing advance. With .045 squish. I rather get domes cut than to change base gaskets. Base gasket is part of the port timing. Quote
hercalmighty Posted March 20, 2016 Report Posted March 20, 2016 Ok I know before without the stroker in it but I had 20cc domes in it that were not cut obviously it was stock stroke but I was at 165 psi and I ran pump gas 92 or 93 and it ran greatA 20cc stock stroke dome vs a 20cc 4mil dome is huge. I ran pretty much the same setups. 165 psi with stock stroke domes and about 185 psi with the stoker domes. With the 20cc stoker domes I had to run 110 octane. I switched to 23cc stoker domes and had about 160 psi and ran 93 octane Sent from my VS990 using Tapatalk Quote
sleeper06 Posted March 20, 2016 Report Posted March 20, 2016 Lil jake it simple math your taking the same cc dome and stuffing added volume from stroke n bore so uccr goes up considerably. On stock cylinder 23.5-24 cc domes is safe for pump n a lil timing. You can defiantly push the envelope as long as you read your plugs correctly and have a good ear n feel for the engine . If your not so great at tuning and maintenance go with the bigger dome . Shoot for .050 squish on any of your domes and it will last Quote
