dittmer Posted December 2, 2003 Report Posted December 2, 2003 I drained both of my carb bowl to work on my shee when i put it back together i noiced i was leaking gas from the drain hoses i tried to tighten the drain screws a little more but it still leaked i then bought new drian screws and replaced the old thinking i had f'd up the old ones this seems to have fixed one carb but not the other can anyone help me with this? i have been told it mite be my float but it does not leak from the upper hose only the lower THANX Quote
locogato11283 Posted December 2, 2003 Report Posted December 2, 2003 check to see if something is holding up ur float. i had the same problem with the needle and seat. pulled that out and had something in there. get an inline fuel filter, havent had that problem since. Quote
boonman Posted December 2, 2003 Report Posted December 2, 2003 http://www.bansheehq.com/forums/index.php?showtopic=18505 You have a float stuck. The lower hose is the overflow........ Quote
dittmer Posted December 2, 2003 Author Report Posted December 2, 2003 I KNOW NEXT TO NOTHING ABOUT CARBS, but i thought each carb had two tubes one for draining the bowl, and the other is an over flow for the bowl am i correct in my thinking and if so how is it comming out of the drain Quote
dittmer Posted December 2, 2003 Author Report Posted December 2, 2003 ok i understand i am wrong about what hose is what can you tell me what the top one is for? Thanx Quote
txblueshee Posted December 3, 2003 Report Posted December 3, 2003 Your floats got dry or it is hung. Take the handle of a heft screwdriver and beat on the carb bowl. Mine did it after a rebuild. Mike Quote
