Look like banshee hubs, not 100% on that tho. They are the same bolt pattern either way. See if your rotors mount up on them
  • 3 weeks later...
YFZ hubs are shorter.
If you swap over to YFZ spindles you cant use your banshee hubs unless you get some short castle nuts , OEM wont align cotter pin holes.
