Hey guys new to the forum this place seems to be a great community SO that being said I have my first issue I'd like to post and ask for some feed back on! I have an 01 banshee and whenever I roll it by hand it feels like its fighting back and doesn't want to roll freely for the first couple of feet and makes a god awful screeching noise, so I pulled off the front wheels and tried spinning the hubs by hand and the front left struggles for the first quarter rotation then spins freely, doesn't feel like the bearings and because of the screeching I wanna say the caliper is getting hung up for the first little bit of rotation. Any remedies?
I usually drain fluid , remove caliper . Put banjo fitting back in and thoroly degrease. Pop piston out with compressed air clean everything with brake clean n compressed air . Look at seals replace if necessary, lube it up with dot 4 reinstall pistons , reinstall caliper n try again
