gonegrizzly
About gonegrizzly
  • Birthday 05/21/1996
    Western Mass
    01 banshee dual pro circuit exhaust, pretty stock so far but she'll get there
gonegrizzly's Achievements
  1. UPDATE ran a compression test on both cylinders and they were both at 135 or so, put new plugs in and she's idling and running fine
  2. Went trail riding yesterday, came around a corner in 4th and ended up going through a drainage ditch in the middle of the trail, snapped the clutch lever off the bars and ended up stalling the quad, I pulled the clutch cable by hand got it into neutral and started the quad, left cylinder was firing just fine but you could tell the right cylinder wasn't firing properly just by looking at the exhaust coming from the silencer on the left vs the right, so I checked my spark plug wires to make sure they didn't hop off on impact by chance, nothing so I started riding and it back fired like a fire cracker on the right cylinder several times and wouldn't fire properly finally I limped it home and when I got to the yard I noticed it wasn't back firing anymore and I believe both cylinders were firing again, I really didn't wanna keep it running any longer to find out and possibly cause more damage so I parked it and asked around for a compression tester, so today after work im going to toss the compression tester on it to see if I threw a ring. A buddy of mine suggested that I fouled a plug so the fuel would just build build build in the cylinder and then fire at once causing the louder noise but I have a nack for never getting off that easy when my toys break
  3. My other thought was that I fouled the plug and the fuel would build up in the jug and finally fire after a while causing the fire cracker sound
  4. Compression test was my first thought bur I can't get my hands on one until tomorrow so I posted looking for thoughts in the mean time
  5. Hey guys I went out riding today, ended up smashing a ditch in 4th and breaking my clutch lever clean off, when I got it running again it sounded fine then it started sounding like there was a fire cracker in my right cylinder and exhaust, not like it was back firing but it was just not firing then BOOM like a fire cracker, very noticiable over the other piston firing, did I blow my top end or did the impact of the ditch hop my float in the carb???
  6. Hey guys I went out riding today, ended up smashing a ditch in 4th and breaking my clutch lever clean off, when I got it running again it sounded fine then it started sounding like there was a fire cracker in my right cylinder and exhaust, not like it was back firing but it was just not firing then BOOM like a fire cracker, very noticiable over the other piston firing, did I blow my top end or did the impact of the ditch hop my float in the carb???
  7. I'll pull the caliper off to make sure once I get out of work
  8. Hey guys new to the forum this place seems to be a great community SO that being said I have my first issue I'd like to post and ask for some feed back on! I have an 01 banshee and whenever I roll it by hand it feels like its fighting back and doesn't want to roll freely for the first couple of feet and makes a god awful screeching noise, so I pulled off the front wheels and tried spinning the hubs by hand and the front left struggles for the first quarter rotation then spins freely, doesn't feel like the bearings and because of the screeching I wanna say the caliper is getting hung up for the first little bit of rotation. Any remedies?
