allboutwork3203 Posted November 25, 2015 Report Share Posted November 25, 2015 I what a upgrade a Lil bit nothing major looking for the best rout to go I have some 34 mm carbs I want go 4 mil stroker v force 4 reeds billet intake t5 pipes seperate k&n filters pro design 22 domes and a over sized radiator no cub motor just want to upgrade and still be very reliable tell me what you guys think Sent from my SM-N900T using Tapatalk Quote Link to comment Share on other sites More sharing options...
gusto Posted November 25, 2015 Report Share Posted November 25, 2015 First and foremost get a reputable builder and do the supporting mods which will keep your engine alive longer. Buy a quality crank and quality clutch. If you already have t5 pipes fine, if you don't get something else. Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted November 25, 2015 Report Share Posted November 25, 2015 Supporting mods are going to be what you want to get lined up first. Then your cylinders will need to be ported for the 4mil (spacer plate shouldn't be thought of) get some custom domes cut for the 4mil. Supporting mods: billet impeller, good clutch, pancake bearing, billet basket, pro-mod trans (when you start making any real power shifting becomes an issue), bearing detent, adjustable timing plate, poly case saver, good reeds, good intakes, big radiator. Etc. Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted November 25, 2015 Report Share Posted November 25, 2015 T5's are decent pipes, but if you're looking for wot, top end power, you'll want something different. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted November 25, 2015 Report Share Posted November 25, 2015 A properly tuned motor with no air leaks and good parts will be a reliable motor. Don't think that just because it's a "cub" or "serval" that it won't be reliable. That's far from the truth. You should tell us what kind of riding you do, what's your budget, and how much power you want. 1 Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted November 26, 2015 Report Share Posted November 26, 2015 My servals have always been reliable Quote Link to comment Share on other sites More sharing options...
camatv Posted November 26, 2015 Report Share Posted November 26, 2015 535 cheeta 6+years with no rebuild 485 cheeta now on its 5th season multiple 421 cubs that have ran into 3 years with no issues. its all in how they are built, tested, tuned after the build and the quality of the parts installed. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted November 26, 2015 Report Share Posted November 26, 2015 3 years on my cub now and we beat the fuck out of that thing. Sent from my LG-H811 using Tapatalk Quote Link to comment Share on other sites More sharing options...
