slag_350300 Posted October 16, 2015 Report Posted October 16, 2015 (edited) I have brand new vforce4 reed valves to put in my bike. It came with some intake manifolds that I've been trying to sell on here to get different ones, but no interest. So I'd like to make them work. Question is the vforce valves won't pair up to the manifolds I have due to the fins that come out the back. Should I be alright to order some reed spacers to extend out past the fins so the valves will seat properly ? I've talked to several different builders and they all recommend UPP manifolds since they are not pushing the carbs and valves out too far. I'm after what's best for performance and reliability so what do you guys think? Go with some spacers or just keep on plan #1 and go with UPP manifolds ? Sent from my iPhone using Tapatalk Edited October 16, 2015 by slag_350300 Quote
slag_350300 Posted October 16, 2015 Author Report Posted October 16, 2015 Sent from my iPhone using Tapatalk Quote
Sandking Posted October 16, 2015 Report Posted October 16, 2015 If it's the stock manifold cut the fins off flush per the instructions. Quote
Sandking Posted October 16, 2015 Report Posted October 16, 2015 Nevermind I see the pictures just get a upp manifold Quote
2smokesJg Posted October 16, 2015 Report Posted October 16, 2015 Bump Sent from my iPhone using Tapatalk Quote
n2otoofast4u Posted October 16, 2015 Report Posted October 16, 2015 Buy new intakes, or get out the grinder. Quote
Bennett131 Posted October 16, 2015 Report Posted October 16, 2015 Bump Sent from my iPhone using Tapatalk Why are you going around bumping people's posts for no reason dummy? Quote
willaduncan Posted October 16, 2015 Report Posted October 16, 2015 Why are you going around bumping people's posts for no reason dummy? Hopefully Tyler will ban him for being a retard Sent from my iPhone using Tapatalk Quote
2smokesJg Posted October 16, 2015 Report Posted October 16, 2015 Sorry guys I'm new I was told to bump convos to be able to post my own thread sorry again Sent from my iPhone using Tapatalk Quote
slag_350300 Posted October 16, 2015 Author Report Posted October 16, 2015 Thanks for the bump 2smokes, welcome to the forum. UPP intakes are on order. Decided to go with builders recommendations. Although they did tell me to use 24cc domes on my redline built stock cyl top end for a 4mm crank running off avgas. Still unsure why they recommended a size equivalent to stock Quote
sheerider11 Posted October 16, 2015 Report Posted October 16, 2015 Thanks for the bump 2smokes, welcome to the forum. UPP intakes are on order. Decided to go with builders recommendations. Although they did tell me to use 24cc domes on my redline built stock cyl top end for a 4mm crank running off avgas. Still unsure why they recommended a size equivalent to stock Wait. What? Are these redline recommendations? Or an outside source? Quote
slag_350300 Posted October 16, 2015 Author Report Posted October 16, 2015 That is what cam told me on the phone yesterday, that he wants to try 24cc domes. I didn't think about it till after I hung up with him hat he said that. I'm gonna call him on Monday and check on my status and see why he recommends that size Sent from my iPhone using Tapatalk Quote
slag_350300 Posted October 16, 2015 Author Report Posted October 16, 2015 Because with a 4mil, 24cc isn't stock compression ratio anymore. Yeah I imagine he knows what he's talking about, it just kinda made me wonder. I think on my last banshee I had 21cc domes and it was also a stock cylinder dune port 4mm crank setup for avgas and sea level riding Quote
camatv Posted October 16, 2015 Report Posted October 16, 2015 why not head over to your local machinist shop an just have them mill off those vanes.. then port match intakes to the v fose reeds..??? why no suggestions like that.. 1 Quote
