4mill Complete Top End
Drag Ported Stock Cylinders, porting done by Alan Cain
66mm Blaster Pistons
19cc Race Gas Domes
Compression Tested at 170PSI before pulled
Low hours runs hard
Bolt on and go
No studs for head
$450 Shipped
Gifted payment or pay fees
I have a correction to make.... the piston size is 66.25 Blaster pistons.
I also want to disclose a very micro crack on the left cylinder only see picture
No problems running this set up
22ab2b29-cf76-4e37-8aaf-0044b9466bab_zps
nasty spot for a crack, props for being honest for the sale
Thanks
That crack makes zero difference. Will have no effect.
I agree. Just wanted to show it.
  • Like 1
the crack I see wont affect anything. its just the aluminum casting. the steel sleeve behind it wont be cracked.
  • Like 1
I understand, just wanted to make sure that other people dont get carried away on whether that cylinder is junk
Bump for some good looking ported cylinders
Thanks again for pointing that out. These are excellent cylinders and a lot of work was put into them!
  • Like 1
Glws those have a ton of work done, that's a 7-9 Hundo port job
Yes a lot of work was done on these cylinders! They run hard!
What base gasket is needed to run these and what are the exhaust and trans timing
Stock base gasket. No spacer plate. Ran with a 4mil crank.
I don't know what the timing is.
