dittmer Posted November 30, 2003 Report Posted November 30, 2003 my stock 02 shee is leaking coolent around the head studs i have changed the headgasket and it still leaks is this just the "NORMAL" kind of crap i will have to live whith as an owner of a shee Quote
97redshee Posted November 30, 2003 Report Posted November 30, 2003 sounds like the head may be warped. Quote
Chemical Castration Posted November 30, 2003 Report Posted November 30, 2003 Did you put the bolts back on in the proper order?? Quote
MRMOONEY Posted November 30, 2003 Report Posted November 30, 2003 could be a loose stud also, i have seen them work there way out, and no this is not something that SHOULD happen, but it is a hobby right hobbies are expensive right. thats why there so much fun lol Quote
bignasty1 Posted November 30, 2003 Report Posted November 30, 2003 no you shouldnt have to deal with lil problems like that. my friend had that problem and it was cuz his head was warped he switched it out for a cool head and hasnt had a problem since. Quote
NYUK Posted November 30, 2003 Report Posted November 30, 2003 proper torque? tightened in the proper sequence? try a different head like these guys said,an o ringed head will seal better. Quote
dittmer Posted November 30, 2003 Author Report Posted November 30, 2003 Thanks for the replys i folowed the pattern in my clymer when torquing the head so i think ill check to see if my head is warped if it is warped how much can i shave without making other mods or using race gas i run 92 octane now, Thanks again ps i know shees are not pos im just frustrated Quote
wesw Posted November 30, 2003 Report Posted November 30, 2003 i going to chime in here no they are not p o s they can be major pain in the ass.. if its not something then its something else can be tiresome but when it works out and run like a streak of shit it is worth it Quote
