xTHUNDERCATx Posted August 8, 2015 Report Posted August 8, 2015 (edited) I have a carrier that was running a single 40mmx62mmx24mm bearing per side. I'm swapping in new bearings but I'm not sure if it would be better to run 2 40mmx 62mmx12mm bearings (The kit JJ&A sells) or getting a set of direct replacements. Any opinions on this one? Edited August 8, 2015 by xTHUNDERCATx Quote
xTHUNDERCATx Posted August 8, 2015 Author Report Posted August 8, 2015 Is there a reliability difference between the set ups or is it about the same either way as long as they aren't crappy bearings? Quote
xTHUNDERCATx Posted August 8, 2015 Author Report Posted August 8, 2015 (edited) Double post. Edited August 8, 2015 by xTHUNDERCATx Quote
Lowflyin Posted August 18, 2015 Report Posted August 18, 2015 Sorry don't check back much but my thoughts are, if you have a single bearing locked up on one side it may be Way tougher to get it home rather than 1 out of 2 bearings locked on a single side. If that makes sense. Sent from my LG-D850 Quote
