RagunCajun Posted August 8, 2015 Report Posted August 8, 2015 Well that will depend on the engine and chassis set up. I'm in the same boat as you. I'm ordering a few different sprockets and then I'm going to have to do a lot of playing around to see. I'll have a very strong engine that can pull a low ratio but I'm not even looking to go fast. I will be see what is ideal in 1st-4th gear. Hell, this is the first time in 5 years I've had 6th gear due to used to having an override. Quote
trickedcarbine Posted August 8, 2015 Report Posted August 8, 2015 Well that will depend on the engine and chassis set up. I'm in the same boat as you. I'm ordering a few different sprockets and then I'm going to have to do a lot of playing around to see. I'll have a very strong engine that can pull a low ratio but I'm not even looking to go fast. I will be see what is ideal in 1st-4th gear. Hell, this is the first time in 5 years I've had 6th gear due to used to having an override. I think you posted a thread below what ya wanted. Quote
trickedcarbine Posted August 8, 2015 Report Posted August 8, 2015 I'm new to the banshee so not really sure. That's why I'm here Sent from my iPhone using Tapatalk New domes can certainly wake a motor up. 21CC is usually pretty safe in a stockish set up. As long as it doesn't have a bunch of timing you should be fine on pump gas. Quote
401k_hav Posted August 8, 2015 Author Report Posted August 8, 2015 I was gonna add that wit a timing plate. I do t care what top speed is really. What matters is how fast I can get to it. But I wanna be at least 70+ mph Sent from my iPhone using Tapatalk Quote
