He has some knowledge of what he is trying to do and is asking for help. If you notice, that attitude goes a long way on here.
ya and still nobody is helping him. oh wait you did tell him to chamber the ports hahaha
like i tell everyone else, pick up some used tools from ebay and a few sets of used up jugs at $30/pair and practice a bit before touching your good parts
Big weave the best knowledge is gained tools in hand , intended use of cylinders is allways a starting point that will depict sizes and volumes of ports . Everyone has there own style and hand work, better tools better job. You can overthink things on paper very easily I've seen very well thought out cylinders still run like shit , a few adjustments and they scream without adjusting a single port timing. Some people like to do the math , I like spinning on a degree wheel for final timings. I will rough cut everything within a mm of where I think it should be , bore/hone, degree wheel and finish you can't give metal back
  • Like 3
This guy has actually posted pictures of his cylinders, more than you have ever done. Guess he isn't scared of someone steeling his work through a picture on the internet.
That is always the tipping point it seems.
Difference, this guy didn't come in acting like a hard ass know it all (like ru). He has some knowledge of what he is trying to do and is asking for help. If you notice, that attitude goes a long way on here.
Yea but let's be honest RU is a troll and even the regular Joes get beat up as well when they do this sort of thing...
I tried porting a set of cylinders once. That was then end of that.
Now I just send it to people that have the patience and experience. It took me about 3 weeks to do 1 cylinder. 2.5 to do the other.
Ran okay. A little bit better then stock.
  • 3 months later...
New Stuff!!!
after a long time of working, family and so on i did some care to my project.
at first i did some portmaps (not complete) of my jugs and im very scared about the bad quallity of yamahas production.
very different port timing on the ports. see the pics and compare.
note: the numbers are not 100% right
an now some basic question.
you see the pic with the cutted cylinder an the port matching to the porttunnel (big arrow). It is better to glue the section with liquid metal or reshape the sleeve port?
in the second case the porttimes are very high?
i hope you can discuss this with me ;-)
URL=http://www.pic-upload.de/view-29063523/zyli_buchse.jpg.html]zyli_buchse.jpg[/url]
Edited by Robert80
on the older cylinders from yester year its not uncommon to see mismatches between the sleeve and casting or the window dimensions to differ from side to side. some hondas had the same problem. even some of the older plated cylinders had window heights that varied from side to side. i prefer to assemble the topend and use a degree wheel to figure everything out rather than measuring from the top down
What port are you after, at very least all entries into the cylinder have to be matched , cut, squared up, blended into casting. I also use a degree wheel it's faster n easier than math
  • 3 years later...
