BANSHEERSA Posted July 21, 2015 Report Share Posted July 21, 2015 I was drag racing and when i crossed the finish line and pulled on the clutch it mad3 a pop and the clutch cable felt loose now i c the clutch actuator is bent so i straighten it and put cable bsc on but it wont pull out of the motor it jus bends ??? Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
bmccormick08 Posted July 21, 2015 Report Share Posted July 21, 2015 Sounds like the pushrod is welded to the actuator arm Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted July 22, 2015 Author Report Share Posted July 22, 2015 Ok so what do i need to do? Im nt a mech but i have common sense but tell me if im on the right track. So i need to take the clutch cover off and check c if there is any debris nside if nt jus pull out the acc. And replace it? Am i on the track? If nt plz help me Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Wadester555 Posted July 22, 2015 Report Share Posted July 22, 2015 Go check our sparkeys garage clutch videos, they will help you! Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted July 22, 2015 Author Report Share Posted July 22, 2015 Thx man Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Wadester555 Posted July 22, 2015 Report Share Posted July 22, 2015 No prob, text me at 5802738251 and I can also help you out and have some parts it you need them Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted July 22, 2015 Author Report Share Posted July 22, 2015 Sweet where u located? Im n Douglasville Ga im prob gonna need the stuff to fix it i would like to make it to the track on fri nite my / 678 615 9166 Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted July 22, 2015 Report Share Posted July 22, 2015 Lol you most likely will have to split the cases , when push rods weld to the actuator they nurl the push rod and can't be pulled out clutch side . Do you have a pancake bearing on the pressure plate Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted July 22, 2015 Report Share Posted July 22, 2015 Put a pancake bearing in it regardless. Cascade sells them. Quote Link to comment Share on other sites More sharing options...
