1988 It is imaculate I just finished building the motor, has only 20 hours .
Here is the list.
4mil stroker motor
Hotrods 4mil, 115mm long rod welded and trued crank
66mm 795 series Wiseco pistons (80 over)
There is no spacer plate under the juggs I had the 22cc coolhead domes milled for the higher stroke.
Lectron 38mm drag carbs ( can be used for alcohol)
Mild dune porting on the heads
K&N filters
Marvin Shaw nitrogen comp shocks
6" extended chrome swing arm
Dune Handel bars and headlights
After market timing plate
Aftermarket stator
Aftermarket clutch boss and plates
Billet water pump impeller
All aftermarket chrome a arms tie rods
CPI exhaust
Coolhead
TPI rims with paddles
Also comes with set of stock rims and tires
LED blue undercarriage lighting
for 3800? bike is clean powdercoated frame and painted plastics
I saw this add, those don't look like cpis to me. I think they are toomeys. Which isn't a huge deal but my first thought is what else is he lying about.
think im going to just hold off till someone puts out a good deal on here
  • 2 months later...
It actually looks like an ok deal but if you go look at it make sure you know what your looking at or find someone who does. Like I pointed out those arent CPI pipes and someone else mentioned you dont port heads. But the bike is cleaner then most you will find in the price range.
