Wadester555 Posted July 5, 2015 Report Posted July 5, 2015 Starting 4mil long rod build, what brand crankshaft should i get? and with a 4mil the cases dont need trenched right?, also what brand pistons, im getting cyls 4mil dune ported, what head should i run with this setup, will get some pwks 35s unless i shouldnt, and what reeds, and then what brand clutch should i get. getting lockout clutch to. THANKS Quote
tfaith08 Posted July 5, 2015 Report Posted July 5, 2015 Hot rods No trenching with a 4mil Wiseco pistons Any head that uses pd domes. VF4 reeds No clue on lockout Sent from over there. Quote
Wadester555 Posted July 5, 2015 Author Report Posted July 5, 2015 Hot rods No trenching with a 4mil Wiseco pistons Any head that uses pd domes. VF4 reeds No clue on lockout Sent from over there. Thanks Quote
trickedcarbine Posted July 5, 2015 Report Posted July 5, 2015 795 series weiscos. Lock up will depend on porting. But a Dune ported 4mm with good pipes is borderline in my opinion. I am one of the few that prefers a lock up even on bikes that don't need it since it allows you to run way less clutch spring pressure so the lever is nice and soft. Quote
Wadester555 Posted July 5, 2015 Author Report Posted July 5, 2015 The pipes will be CPIs in frame Quote
trickedcarbine Posted July 5, 2015 Report Posted July 5, 2015 Ya, you're looking at a fun build. Quote
salmon_slayer06 Posted July 8, 2015 Report Posted July 8, 2015 Did same build. I went through FAST for the port work, domes, correct base gaskets, and all the little extras. I ended up blowing a head gasket last winter from leaning the motor because the stock fuel petcock was too small. I put a pingel on I suggest doing the same. I built mine for trail riding. Its good for what I do. Biggest problem is fuel mileage. In one day of riding I'll go through 15-20 gallons. Like the power it has. The cylinder bores are a little messed up from the head gasket failure but I'm going to take care of that. I'm thinking of getting a second motor to save on down time. Quote
