Wadester555 Posted July 3, 2015 Report Posted July 3, 2015 (edited) Changing some stuff on my shee, specs Stock carbs 320 Mains and 25 pilots clamp on filters with outwears stock reeds std port stock crank cpi inframes also run 32:1 gas mix im getting pro design head but dont know what size domes to run can you guys help? thanks Edited July 3, 2015 by Wadester555 Quote
Wadester555 Posted July 3, 2015 Author Report Posted July 3, 2015 elevation 900- 1,909 my town is 1909 and little sahara is 900. And i think it is 91 pump gas Quote
sheerider1026 Posted July 3, 2015 Report Posted July 3, 2015 I've ran 19cc @ 650ft. But not stock porting. Quote
Wadester555 Posted July 3, 2015 Author Report Posted July 3, 2015 alright thanks, any other suggestions Quote
sprinklerman Posted July 3, 2015 Report Posted July 3, 2015 alright thanks, any other suggestionsGet a Noss or Chariot head instead of PD.Good deal on one in the FS section right now. Sent from my SM-G900R4 using Tapatalk Quote
Wadester555 Posted July 3, 2015 Author Report Posted July 3, 2015 Get a Noss or Chariot head instead of PD. Good de add l on one in the FS section right now. Sent from my SM-G900R4 using Tapatalk any reason why, alot of people say that i just like the looks of them but doesnt matter Quote
sprinklerman Posted July 3, 2015 Report Posted July 3, 2015 any reason why, alot of people say that i just like the looks of them but doesnt matterLess parts, don't require special studs,less orings. Sent from my SM-G900R4 using Tapatalk Quote
Wadester555 Posted July 3, 2015 Author Report Posted July 3, 2015 Less parts, don't require special studs,less orings. Sent from my SM-G900R4 using Tapatalk do you know daves name on here? Quote
sprinklerman Posted July 3, 2015 Report Posted July 3, 2015 Go to the sponsors page,get his number and just call him. Or even easier is to call Redline or FAST, order head and domes at once. They'll spec out the CC you need. Sent from my SM-G900R4 using Tapatalk Quote
Surfrjag Posted July 4, 2015 Report Posted July 4, 2015 consider having your crank trued and welded? Quote
trickedcarbine Posted July 4, 2015 Report Posted July 4, 2015 Changing some stuff on my shee, specs Stock carbs 320 Mains and 25 pilots clamp on filters with outwears stock reeds std port stock crank cpi inframes also run 32:1 gas mix im getting pro design head but dont know what size domes to run can you guys help? thanks Nobody else caught the stock pilot with CPI's and Pods? Get that swapped to at least a 27.5 pilot. It may eat a 30.... Definitely would with reeds. Domes, 20-21 CC wood wake it up, but the crank would probably fare better with a quick weld. If not definitely 21-22's Quote
