I cant figure that thing our on bluetraxx so how much speed will it increase If I add a 17 inch sprocket I have stock right now. And what can I do to make the speed get there faster after I add it?
I'm guessing your doing asphault racing??? If the motor can pull it, the 17 in the front should get you around 95mph w/ 20" tires. 22" tires will get you around 100mph w/ a 17 front sprocket...You'll need some decent mods to be able to pull it though....You'll need some serious mods if you plan on running this gearing on dirt...and even more if your running on sand w/ sand tires....
