I got to take it out Friday.  The Banshee ran good overall.  I had very little bottom end, but in the high end it pulled.  it must be the port that I have that makes it want to run hard and fast at high RPM.  Does that sound right?  I was in deep soft sand, so I had to run high rpm.  To me it seemed like the coolant was a lttle on the warm side, it did not take long to get 180 degrees celcius, with running high rpm and quick passes there was not much for air flow.  Is there an ideal coolant temp, should I have been worried at 180?
Thanks.
I really hope you mean 180*F because if you truly mean 180*C, that's 356*F...
You need to do a leak down test and stop riding it NOW!!
http://bansheehq.com/forums/index.php?/topic/110585-leakdown-tester/
BTW, ideal riding coolant temp is 180-200*F.
At 220*F I'm looking for a strong head wind to ride into at a moderate pace to keep air flowing thru the rad.
