wth is my problem, i have been told it could be my clutch, clutch lever adjustment, stretched clutch cable causing adjustment to be wrong, foot lever in wrong place.
i suspect clutch because i just replaced it, adjusted it so the arrows aligned, but when i let out on my clutch lever it grabs nearly fully disengaged, maybe my clutch cable is in fact stretched causing it to be out of adjustment?
Do a google search on this, there is plenty of info out there. Sometimes your clutch release arm wont work quite right if its lined up with arrow on case. I had mine set with the pointer and arrow lined up but would kill it everytime I put it in gear, and it was near impossible to find nuetral. I adjusted the clutch to were the arm is to the left of case arrow and haven't had a problem since. As tricked stated, check you eccentric adjustment
