Hello, i have a 95, 65mm bore. I parked mine yesterday, didn't have no problems, as i went to crank it over to start it back up, the kickstarter was catching. At first i thought, maybe my crank is bad, but i pulled it apart and checked the crank and it was fine, but when i go to turn it over it catches at one point, please help, thank you.
They need to be pulled and pressed on, so if you got access to that it's easy. I'd definitely have yours checked for trueness and phase, and get a quick weld on it at a minimum.
